What CV Boot clips do you use
RichValver
Car  Clio 16v/172 daily
So usually I use the boot clamps in picture 1, but I have absolutely no clearance on my Megane 225 cv joints so need the most slimline clamps I can get. I had to use a metal cable tie type like pic 2 as its all I had to hand.
So what clamps do you lot use and what would you recommend out of these
I usually use the Oetiker clamps like pic 1.
How much clearance do you need?
Can you clamp them down tight and then flatten the tab a bit more with a hammer, i've done that before.
Every time I tried hammering them down they loosened off on me. There's barely anything. Like using those type clamps it was hitting the hub and undoing itself
I managed to get away with the j&r cv joint/boot but like I said, they supply the wrong clip that fouls. So il order some of these style clips to do the other side
