106 GTi
and the smell from all the wheelspins and hand brakes turns
Of course nowt J Turns like a hire shed!
What is it then?
ECU map for emissions or something
Yessum nout to do with the cat :rasp:
also the vvt system isnt activated until the coolant warms up slightly, why... good question...
I thought it was done on coolant temp hence the bad running when cars had the temp sensor issues.
How would the temp sensors reading the coolant temp as low affect the running/ idling? This is a genuine question if that sounded sarcastic in any way
What the ECU does is governered by weather the coolant is below or above a certain temp. I.e the rev limiter cutting in early is down to the coolant being below a set temp.
i love the smell of coffee and clutch in the morning
Its to get it to pass the cold start emissions iirc.Mine feels like the air filters blocked or theres not enough fuel getting through for the first couple of minutes....l guess its set up like this to protect the engine when cold ????
