What engine oil for track car
Car  Clio 172 + megane 25
What engine oil and grade would be recommended for a track car? It has a set of cams, throttle bodies, upgraded conrod bolts and valves, I am also using an oil cooler? Stuck for what oil to use
I use Shell Helix ultra 5w 40, which is only £20 for 5L at ECP with discount code SAV852964. Always used it in my performance cars N/A & TC and its always performed well.
Many thanks for the replies :up:
So would it still be okay to use the millers nanodrive 5W-40 for track or would it be better to switch to 10W-50?
I use 10w60 Castrol oil as I'm on fancy timing and had rather low oil pressure using 5w40. 10w60 brought it up a good few psi.
Done an oil and filter change with my 5/50 , I previously quoted 10/50 sorry beg ur pardon.
Cold start 4 bar oil pressure , happy with that
IMG_1125.webp I use Elf 15w50 Competition ST oil in mine, its down to what purpose your using you car for, Use the same oil in my Escort and Sierra Cosworth and my Impreza type-r....
