If only using the single amp then 4awg will be fine....
If any chance of future upgrades, (for example this amp driving fronts bridged or fronts & rears plus a beefy mono), then I would fit 0awg now to save doing it again later....
0awg is totally overkill for the above applications...
Ive run 3 amps all from 4 gauge before, never had any power issues. All on JL audio gear too.
original poster, 4 gauge will be fine. nothing more needed. not until you start drawing huge current.
Did you bother reading my post....
^^Good for you
Strange, I thought thats what I said, but I pointed out its cheaper and easier to buy 0awg now and save on added cost and fitting time doing it all again....It's known as 'future proofing'....
The present amp delivers upto 300watts rms into 2chs. (bridged), draw at this output will be around 75amps to 80amps, 4awg at approx 12ft will handle 80 amps with minimal voltage drop.....
Add a 'beefy mono' and 4awg is out the window, if you assume, (as I did), that upto 600w rms into a front set would warrant a matched JBL GTO 14001e mono amp then 0awg becomes a must, (this amp likes lots of power at upto 1500w rms into 2ohm)....
