cat171
		I noticed a few days ago that the passenger side dipped beam doesn’t work, the bulb is new & only been in since June.
When I touch the back of the light it makes a sort of electrical noise (like a motor noise) & the light comes on, the back of it (the black plastic plug part which I touched) gets pretty hot though, a lot hotter than the drivers side one.
Often though after turning the lights off & back on again it won’t work, but if I touch the back of it again it comes on.
The light works fine when it’s not in the bulb holder, even if I move it around it’s fine, but when I put it back it doesn’t work. I have not unclipped it.
What is up with it ? dodgy wire? or the connection? as I say I've not unclipped it & when I moved it around not in in the holder it was fine.
