Ive used Mintex, Wilwood Polys and Hawks.
All pretty good, the Hawks were really nice but not sure how suitable they are for the road. Not sure which type of Mintex pads I used but they were alot worse when cold than the equivilent Ferodo ones
The only reason I ask if they use the same pad as I used to have superlites, and thinking about it were replaced with what I think might be midilites, but they use the same pad.
If you look on the Tweeks or GPR catalogues it has the sillouette and dimesnsions of the superlite pads so if you have some worn ones that fit your midilites you'll beable to see if they are the same
