what pressures to people run in there r888's
reet peeps.........im on a bit of a mission regarding the r888's, basicly im intreged to know what people run, i run a max 20psi in mine any higher and theres just no grip....anybody else find this??
i respect not many peeps will run these on the road...but if any do can i have input:)
cheers, norm!
  Mk2 172
Its all about temp tbh. they work at there best between 80-90 degrees. They recommend running them at 32-34 psi when they are up to temperature (hot) on a car that weighs approx a tonne. This info was given by TOYO themselves when i investigated this for my car using the R888 on track. The guy i spoke to has been racing for over 15 years so i guess hes got some idea. the hardest thing about them on the road is that u will struggle to get the proper temp into them.
  Mk2 172
no worries. Ive done loads of research on them for when im on track. they need to be right to work properly :) 20psi is way way to low. I think its about 26-28 from cold providing u can get the temp into them
