These orange lights came on a couple of days ago, not noticed any difference with the car at all. Its a 1.2 16v Billabong done 42k miles. Anything to worry about?
Cheers Guys, i suppose with the car showing no symptoms it could be a number of things and no way of really knowing until i pay the £30? Might leave it until i start to get some symptoms then ill be able to have a go at fixing it myself as it will be eaiser to highlight the problem.
i pressure washed my engine bay and that light came on, it revved at 5000rpm and wouldnt stop, i took everything off and tried cleaning/drying it in the end it was a white plug in the fuse box, may be an option for u if uv recently pressure washed under ur bonnet
Thats what im expecting it to start doing. Ive heard in this case the throttle body just needs cleaning out with a bit of carb cleaner but its a b**ch to get at.
Mine always used to do this, it would either refuse to rev above 3K or would sit and rev it's tits off to the limiter. Turned out the wires at the back of the engine block were being chaffed away by the metal cover over it. the
