what's my broken bit called ??
Car  clio
Hi All, Merry XMAS !!!
I wonder if anyone can help, I seem to have a problem with leaking fuel.. it seems to be a faulty plastic connector that plugs on near the front/top of the engine near the injector rail.. can anyone tell me what its called so i can look for another..
its about 3-5CM's long, black plastic, one end i assume goes to the fuel hose.. the other end has 2 rubber seals on it and the whole thing should "click" into what i think is the fuel rail.. it seems to be spurting fuel out if its knocked or waggled and seems to not connect snugly..
any help would be much appreciated
Russ
You need a whole new fuel lines £30 or so from Renault the clips are useless realy there not that strong sounds like someone been messing with your if they break if you don't touch them there fine.
Cable tie/duct tape it on intil you can get a new one but idealy don't drive it.
