Whats needed to run a 172 phase 1 throttle on a phase 2????
Car  RB 182 Track Project
As title guys, what do I need to run a phase one throttle set up on a phase 2 172?
Can the phase 2 ecu still be used or does it need changing?
Don't think you can do it, unless you change the engine loom too, as the ph2 doesn't have an idle control valve, so no wiring for it
So if it can be done id say you would need
Ph1:
TB
accellerator pedal
ecu (I expect Paul at RS tuning will know if you would need a Ph1 ecu
Inlets (for the icv hole)
ICV
engine loom
throttle cable
