SEAN16V Car Renault Clio Sep 14, 2011 #1 just woundering which is the best way 2 get stance without using camber bolts as i bought a pair and they dont fir my coilovers thanks
SEAN16V Car Renault Clio Sep 14, 2011 #4 I been looking at shims but I want alot of camber and i want mad camber
D Dan@M.A.D Car RS6 C7 Sep 14, 2011 #6 What wheel you got and how low? Stance is made up on more things than just camber, you need rake, poke,flush, camber.
J JackJack Sep 14, 2011 #7 Bolts for the front shims for the rear. Why can't you fit bolts what coilovers are they?
SEAN16V Car Renault Clio Sep 14, 2011 #8 Ta teknex coilovers the shim don't give you enough camber is there anywhere than do camber shims
SEAN16V Car Renault Clio Sep 14, 2011 #9 I am scraping speed bumps I am that low and I am looking at new alloys knw
D Dan@M.A.D Car RS6 C7 Sep 14, 2011 #10 Scraping speedbumps:clown: i scrape down normal roads no bumps
SEAN16V Car Renault Clio Sep 14, 2011 #11 What's the nest shims for the rear what the best negative camber
