I've driven neither on a track, but currently own both, and have driven them hard most of the time.
Mk1: With standard shockers on it, it sits well into the corners and is pretty responsive - close to a 106 rallye I reckon - by comparison I find my Mk2 ph1 172 to be more vague. I'm running Eibach sportlines and standard (but new condition) shocks on it at the moment - Ill be seeking advice later when I start to turn it into a track machine.
The Mk1 when I last had it running was on crap 185-55-15's and the Mk2 is on decent 195-45-16's.
The distinct differences in Mk1 handling are between the Williams and Valver.... Williams has better suspension, thicker anti roll bar and wider front track, very good handling and a lot of people use them on track with the standard stuff. Valver has a narrower front track and does not handle as well IMO.
Coilovers are not expensive for them compared to the Mk2s, as they do not have a rear spring setup, just a damper. 195/50/15 is usually the tyre of choice on 7inch wide wheels for the Mk1s, as it gives the best all round performance. The best upgrade you can do to a Mk1 (Valver) in terms of handling is fit the Williams (or 172 which is even wider) widetrack to be honest.
