Whats the standard weight of a...
  MINI JCW
its 1059kg
Heres a table I put together some time ago of all the Renaultsport models power to weight ratios, the last two figures are weight and bhp per tonne
Clio 16 v 1.8 137 980 140
Clio Williams 150 981 153
Renaultsport Clio 172 MKI 172 1059 162
Renaultsport Clio 172 MKII 172 1095 157
Renaultsport 172 Cup 172 1011 170
Renaultsport Clio 182 182 1090 167
Renaultsport Clio 182 Cup 182 1075 169
Renaultsport Clio 182 Trophy 182 1070 170
Renaultsport Clio V6 230 MKI 230 1335 172
Renaultsport Clio V6 255 MKII 255 1400 182
Renaulsport Clio 197 197 1240 159
Renaultsport Megane 225 225 1375 164
Renaultsport Megane cup 225 1345 167
Renaultsport Megane Trophy 225 1355 166
Renaultsport Megane F1 225 1355 166
Hope that helps (although im sure it wont look right once it has been posted!)
  172 ph1
Mine weighs 1054Kg an is completely standard no fuel. The book that came with it says the kerb weight is 1035...
  A clio
ive weighed my 182 trophy, with half a tank of fuel, it was 1050kg, the scales wont be more than 10kg out
  VaVa
So a full tank of fuel and you're looking at nearer to the book wieght then.
Everytikme someone posts the weights they are different. lol.
  MKIII 138
those figures are about right although i thought a 172cup was 1020kg being 79kg lighter than a 172MKII at 1110kg, the 182 20kg lighter (no spare wheel or kit) at 1090 (which then ties in with your KG figure and the 182cup was 1075/80kg so that ties in perfectly.
so id say 172cup 1020 , MKII172 1110kg, 182 1090, 182cup 1075, MKI (depending on bonnet) 1060 kg although newer one was a bit heavier but only marginally.
also a 225cup is indeed 1345kg as you mentioned so out of interest what is a 225cup with recaros ?? how much to two side airbags + detonation kit etc.. and the recaros weigh against the full fat full leather beasty`s ? id wager at Least 15kg which was the weight diffo between a 182trophy and a 182, however the seats in the meganesport are deffo bigger and fatter so we could be talking more
so 225cup + recaros is 1345kg - 20kg = 1325kg
whats the power to weight of 1325kg meg then ?
  MKIII 138
ooops reading above the 182trophy was 1050 +/- 10kg so that means the only change between this and a 182 would be 30kg saving ?? seems a lot anyways
1320kg then power to weight please due to extra weight of stock megane chairs thats 25kg lighter and probably about right
anyone know the weight of the recaro seats ?
  172 Ph1/Scooby MY00
I've still got the 172 Cup brochure and it's 1021 kg, 80,000g (they say) less than the MkII Clio 172. The 172 Mk1 figure is 1035 kg.
If you took all the spare parts, nuts and bolts out, Dan, your car would probably weigh 950 kg!!!
Cheers, Rob669
  Williams 2 - Clio 1.9D
The calculation for power to weight ratio is:
Power / weight x 1000
So my valver if where standard would be:
137BHP (Power) / 980KG (Weight) x 1000 (1Ton) = 139.79 BHP per Ton
Hope this helps
