Whats wrong with your car right now??
4 Tyres needed
something knocking from the back
suspension knocking from the front
front of cat exhaust pipe needed welding
belts
pulls to the right all the time..
and not fast enough to catch corsa vxrs :(
Not much mechanically, pretty much sailed through its MOT bar a ball joint, so thought it best to replace both. There is a whine from the engine area though, suspect the pas pump, but bit of a ballache to diagnose?
Cosmetically theres a couple of blemishes on the paint work thats doing my swede in, can wait til next year though, and the standard exhaust will be replaced soon with a piper one. Belts and all other gubbins done in last 6 months.
Front bumper needs spraying
Bonnet needs spraying
Cup spoiler needs spraying
Exhaust mount needs replacing
Needs new oil
Need to fit new number plate light
Grill needs re spraying
That's about it I think...
My sub cut out my electrics, after unplugging the sub it has left the car lagging loads of power and only just about pulls.
main issue currently with the new one is it has no wiring loom so I have no idea if the thing even works.........................that good enough ;)
Nothing, other than an annoying squeak from the front passenger footwell area. I will find it one day lol!
Do not bring that to me then Graham, I'm sick of rack bushes this week and I can't feel my finger tips lol
thought it was this its not its a cracked inlet manifold/fecked mani fold gasket letting it draw way to much air and making it stall
I'd get that fixed first as I've never known an inlet leak trigger the electrical fault light before. I'm not saying you don't have a minor leak but I honestly don't think this is your actual issue.
4 wheel alignment - all four wheels diagonally swapped - still pulls to the left!!?!?!?!?!? arghhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
Needs new tyres
Needs new seat roller its fooked and held by a screwdriver lol
New drive shaft
The serv esp and traction control light come on
My manifold to cat kit fitting
Stupid cars
Currently running on 3 cylinders as my mate did an oil change and spilt some on the top manifold which has now found it's way into a spark plug chamber (at least I'm hoping that's what it is!)
Gear linkage needs some fettling as 1st and 5th are a mare to find.
I have a puddle from the passenger footwell all the way to the back of the car. only on the passenger side though. FUN!!!
I'm having some trouble when i'm accelerating.
The other day on my way home, i hit a piece of debris in the road and it hit underneath my car.
Since then, when i start to drive forward in 1st, 2nd and 3rd gear, it takes about 5 seconds for the car to properly start accelerating. It starts to accelerate but slower than usual, but then gets to a certain point and starts to drive properly.
Does anybody have any idea what it could be? I'm completely stumped.
Heater fan has started to only work now and again. Bad connection somewhere, I guess. Will have to have a poke around at the weekend.
its giving an eml light because the lamda sensors are giving false readings due to running so lean had it smoke tested and its leaking out of behind the ecu on the rocker cover also all 4 ports on the front of the block
and if this isnt the actual issue after spending 70quid on 4 rubber seals the cars getting stripped for parts and scrapped as its had alot spent on it recently
