whats your views on FK highsport coilovers?
anything to worry about??
good and bad things?
anyone fitted them, if so did you come across any problems?
for my mk2 ph2 clio
jay
ummm... hub size?? sorry i dont have a clue when it gets all technical?could you explain more ben please?
yer, there are different hub bolt spacing, on the 1200's you have 52.54,58mm, im sure fks are 58mm so u need to check the distance between the two vertical bolts, you can get at them if you put the car on full lock then sick a small ruller in and mesure them, you will see them they are on the bottom of the strut.
if you have the 52,54mm its not the end of the world you can just buy soem new hubbs off a scrappy n change em over
