Wheel bearing
  Titanium 182
Ever since last weekend my 182 has start to make a winning noise which sounds like to me a wheel bearing.
Couple of questions
1. Will i get it changed under the warranty ( problem is the car is running HR's)
2. How much are they
3. Are the easy to do
CHeers
Leeroy
  Sport 172
1) Give Renault a ring about getting it done under warranty.
2) About £20 I think they are.
3) If it's for the rear wheels the bearing is pressed in the brake disc. If the disc is in good condition then might be best getting a new one pushed in the disc. Think it's about £10 at a garage as you need a bearing press.
  Titanium 182
Booked into Renault for the 21st
Bloke said if it wear and tear the wont replace it,
if its collapsed the well, same thing to me
Also having air con looked at 2 and the sily rattley door card 2
