Wheel bolt size
all i'm trying to do is accommodate the difference in offset. I've got wheels which are a et42. so simple wheel spacers seem ok. I'm really not sure how much goes in or are longer bolts needed at all?
Knuckles
ClioSport Admin
If you have the time, take a wheel off, stick the bolt through, if it sticks out of the back 20mm, 10mm of thread will go into the hub after you fit the spacers so you'll be able to gauge how long of a bolt you'll need.
thats a last resort if someone doesn't come and give you the answer though
