Wheel bolt spec help
The Boosh!
ClioSport Admin
  Elise, Duster
Hello :)
I need some wheel bolts but I don't know what the standard Renault spec is!?
I need some 22mm long wheel bolts but there are about a thousand different sizes!
Thanks :eek: x
The Boosh!
ClioSport Admin
  Elise, Duster
Boom
Hows that looking!
  e92 330i
Perfect. Only 4mm shorter then standard, will that be enough? Best thing to do is take the wheel off the car and bolt through the wheel into the spacer (ovbiously dont put the spacer on the hub) and see how much bolt sticks through.
Thats how much shorter you need to go
The Boosh!
ClioSport Admin
  Elise, Duster
Yeh I've done that. It's literally JUST too long and sticks out by 2 mm when tightened up
jenic
  981 Cayman
19mm head is standard though, so if you get 17mm your toolkit in the boot wont fit anymore.
jenic
  981 Cayman
I only say because the polarised ones I have now are 17mm and mine doesn't fit now lol
The Boosh!
ClioSport Admin
  Elise, Duster
I carry a breaker bar in the boot anyway which has both 17mm and 19mm socket head so it's not a massive issue but would be nicer if they matched
