Most people on here tend to recommend the Momo boss. OMP do one as well but if you have cruise control, the block connector won't fit through the hole (as I recently found out!)
Check the bolt spacing on the wheel you buy also. The boss' for the clio are 6 x70mm PCD. Nearly all aftermarket wheels seem to be 6 x 70mm PCD also but I've seen 6 x 74mm on nardi wheels before.
You probably already know this but you'll need resistors also to avoid the airbag warning light coming on when you remove the old wheel.
