Wheel drama , need advice
Car  Clio 172
Hi , I have been offered some replacement alloys , they are BSA 17" PCD 1143 ET40, will these be ok with spigot rings ?
PCD 1143?
The spigot rings are to reduce your centre bore. From a bigger size down to 60.1 if required. If the centre bore is smaller than 60.1 then they will need machining larger. The PCD on a 172 is 4 x 100, the ET is just about ok but I think a PCD of 114 is from something like a Honda iirc (don't quote me lol) and won't fit as that is the gap between the four bolt holes.
