Wheel offset question...
Alastair.
  986'S 172ph1+182FF
Will i notice a differnce going from et43 to et45 (so the wheels go in 2mm) or is 2mm to small to notice?
  182/RS2/ Turbo/Mk1
Are you changing the width as well?
If you are then you may find the fill the arches better now than before even though the centreline has moved 2mm inwards.
But either way, 2mm isnt a lot really, unlikely to make it look drastically different unless the wheels are narrower too
Alastair.
  986'S 172ph1+182FF
Not changing the width, keeping 8j. Now found some in et42 so i will get them. Just didnt want the wheels to sit in anymore even if it was a little as 2mm. Sorted.
