if i swap the back wheels to the front, do i have to get them rebalanced?
lawrence ClioSport Club Member is non-existent Nov 15, 2005 #1 if i swap the back wheels to the front, do i have to get them rebalanced?
W White16valver Nov 15, 2005 #4 Just be careful if the rears are a lot lower on tread than the fronts - slidey slidey rear end = more lift off oversteer than you might like! lol
E edde Nov 15, 2005 #5 Don't under any circumstances go stick the tyres with small tread on the back. Take this as a work of advice from a person who found out the hard way.
lawrence ClioSport Club Member is non-existent Nov 15, 2005 #6 no ive only had the tyres on for a month just want to get maximum life out of them, the last set i had the rears had hardly budged
stu8v Nov 15, 2005 #7 White16valver said: Just be careful if the rears are a lot lower on tread than the fronts - slidey slidey rear end = more lift off oversteer than you might like! lol Click to expand... It should make no difference within reason.
