Wheel spacers - Help needed
497adam
Car  clio 172 phase 2
Does anybody know of a wheel spacer that will fit rear wheels without fouling rear brakes?
tried those universal ones, too big overlapped pads. can you suggest some that don't ?
only need 3 to 5 mm. Fitted 205 tyres to my standard 172 rim and they are catching arch liners
always buy hubcentric specific to your model of car..... i have a set of eibach 25mm spacer that bolt directly to the hub then you bolt your wheel to the spacer.. safest way to go. you dont want to compromise on safety. good set of spacers like these will cost you anywhere between 60 to 100 odd quid. mine were 115 quid. the build quality on the eibach ones are immense tho
Where did you buy them from? Can you get them in a smaller size?
I had them on my old Punto but only on the rear and never had a problem but I swear I have seen a thread on here where someone had problems with them failing on the front?
anyone got the delta mic ones? they any good or cheap s**te?
They are fine, had a 25mm set of the front of my current car for 6 months and had 15mm set of the front of my previous 172 for over a year. The bolts that come with the 15mm set are s**te though, you will need to change them. However if you go for 25mm they bolts it comes with (to bolt them to your discs) are fine. I've just bought B Centric 20mm FK fronts and A Centric 5mm FK rears, around £30 more than the Delta Mics and are made from alloy rather than steel and as such are a s**t load lighter.
