M micmat Feb 8, 2004 #1 I have decided to keep the 15s---for our conditions it seems the best compromise. Would I be able to kick the rears out by 12mm without rubbing? The car is not lowered. Thanks
B BRUN Car Skoda Fabia vRS Feb 8, 2004 #2 possibly but 12mm is a lot mate............. you would need longer wheel bolts for a start
C case Feb 8, 2004 #3 12 mm is nothing mate,you can go as wide as you want as long as you do it properly. Ive spaced my rears out 75mm either side. You shouldnt get any rubbing at only 12mm, if you do you might need to just trim the inside of the arches.
