Hi RS182,
Glad to see you started this issue.
Wheels rubbing on Cliosport is an old issue. I can remember myself driving from the garage, say 2 yrs ago with my ex-RS Mk I and brand new Semperit rubber (having the proper dimensions for RS Mk I) and whenever the car position was inclined to some extent, a loud rubbing noise was heard.
I pulled over, saw nothing wrong and drove back home.
Next day I went to the nearest Reno garage for a check. And we found the reason for that rubbing: It was a plastic arching above both wheels. The clearance between the wheel and that plastic was barely 1 cm. So the wheel had to rub.
We sorted the problem out by readjusting both plastic arches.
I believe that new 182 suffers from the same bad design.
