just got some wheels off pete smoothed clio, and have problems with the wheels wobbling loads, got the spigot ring on, just wondering if maybe they need balancing, any ideas would be great.ta
you said you have the spiggot rings on the hubs! vibration through the wheels can be caused by inproper alignment when tightening the bolts, always good to do bolts up evenly and opposite each other so they line up in the countersunk holes in the whell properly,
but my guess is that you need the wheels balancing.
KDF
yes your back wheels do need balancing aswell, can cause just as many problems with vibration
right just had the wheels balanced, is better but bloke rekons its down to the spigot rings, not spacers, i have no spacers, just the plastic rings behind the wheels, or prehaps my wheel studs arnt long enough.
