Where can you buy mk2 172 decat pipes
Bubbles
  BMW I4 M50
not mk2 though, only mk1, but they do fit up if you have a k-tec exhaust (cos most if not all of the 172 ones have an extendable section going up to the cat.
rich mate is this the same as ktecs? would i see the same sort of power increases from this janspeed...very tempted at the price:)
  Ford F-150 5.4 V8
Quote: Originally posted by Neil82cup on 21 December 2003
Whats the difference between the Janspeeds Rich?
if you ring the lads at motorsportworld they are really helpful. quite cheap too!
KDF
  Audi TT Stronic
Err, maybe just me but I though the decat for the mk2 172 was out, with both the sensors for the lamda.
No mate its fine, the trick to it is to unplug the second lambda sensor completely and simply tape up the connector, this gives the ecu an untimately clean mix signal and hay presto! it all just works :)
Rich-D
  E90 LCI 330d
No...
This is an actual "de-cat" mate, as in just a bit of pipe, wheras the K-Tec one is a "sports cat" hence the price difference!
Rich-D
  E90 LCI 330d
Not sure myself...
Think they are mk1 & mk2?!
