where to get cams done?
Michaelfoz
  Clios
The belts are needing done shortly so whilst i am getting it done i figured i'd be as well as growing a set and getting a set of cams as well.
so i am looking for somewhere to do:
dephaser, cam belt, aux belt, water pump
428 cams
re-map
RR figures for before and after
camshaft and crankshaft oil seals
rocker cover gasket
anyone got any recommendations, Preferably in Scotland but i will be willing to travel to have the work carried out
also can anyone think of anything else that would be worthwhile doing whilst they are in and around the engine?
Mikey
  Clio 172 cup
I always use Cooksport, however they are in Bath which is a long way from Scotland. If your willing to travel I would highly recommend them.
They have just built a stainless exhaust and remapped my car for me, the difference is unbelievable between the standard engine.
if your going to be throwing a bit of money at it, it might be worth putting some higher spec cams in with updated valves and springs, that way you will see some better gains. You don't want to spend all that money and wish you had gone for a bit more power!!
  225 Cup & Williams
428 cams
re-map
rocker cover gasket
Mikey
Better off traveling down to somewhere like BTM or 519 automotive. If I was you I would get matched inlets fitted at the same time too. Ktec induction kit could be worth a shout too or you could make your own.
Michaelfoz
  Clios
so 438's seem to be the one to go for.
519 could be a shout, im sure i could convince the other half to go with me as long as i take her to b/ham for a bit of shopping afterwards haha
how much would i be looking at for valves and springs?
  WRX
519 : Bedford
BTM : B'ham
Brum's sort of on the way back from Danny I suppose. Or drop off at Fred and go shopping whilst you wait.
  Ph1
You don't need valves and springs.
I got mine done at Renault (years back) as it worked out cheaper when adding up the petrol costs on top of the work.
yeecup
  mk8Fiesta ST,172 cup
You live in Scotland. Swr in Stirling are Renault specialists who also build and race cars, they have worked on many members cars on here including mine and are top notch. Makes me laugh all the English on here that say 519 and btm like they are the only people who can work on cliosports and that we should drive hundreds of miles to them rather than use local specialists. Rant over
  172
think its due to the fact we dont really hear of SWR like you do dan and fred
Michaelfoz
  Clios
i know that swr do work on clios
thats where 99% of scottish people on here take their clios to have belts done
i wasn't so sure if they done cams and RR?
yeecup
They do pretty much everything. They don't have a rr but do have their preferred mapper they use . Of course they can fit cams it's not rocket science. Check their website or give them a call
