Which Brakes will fit my car
the willy/valver discs wont fit straight on as theyre vented discs, yours will be solid
second set should fit... but beware the grooves and holes will fill with dirt and corrode, etc which may actually make them look worse than standard. (i have drilled discs and the holes are filled with brake dust and are slightly corroded looking, bit disappointing)
big disc conversion imo, solid discs, but fill the gap ;)
im in the same boat btw! lol, and thats with drilled discs (standard size)
[Edited by Friction on 09 August 2005 at 12:36am]
Ive got a big disk conversion kit for sale is the ketc one £100 for it.
It looks very good behind the wheels, 280mm disks I think I got rid as my calipers were gone but you ue stok calipers.
Surely for a mag feature you NEED 4 pots and rim filling discs.
Especially after all the money you have spent whats another £1k
Quote: Originally posted by CDMullins on 09 August 2005
Will these def fit mine??Have u got any pics mate, or links to it?
Im sure they will do ring ktec if you ant to check but Mk2 1s (none 1.6 16V and V6 and 172s) use the 239mm disks which is the same size plus use the same pads.
See my PM though.
The pics are here though.
They have got a bit dirty but once you use them again this will all clean off.
