easy, they have instructions with them too you know![]()
fitting mine tomorrow and ive no mechanical knowledge or anything, am i safe to unbolt the bolt at the bottom of the shock to bolt the bar on ? i wont get a spring or anything to the face ? is it ok to do without axel stands/ramps if its easily accessible without ?
i just layed underneath the car and done mine. Its easy, and im a total r****d when in comes to mechanics.
Keep the load on the wheels and you wont need any of that.Doubt it tbh, you need to support under the coil spring so that it's still compressed when undoing the bottom shock bolt, otherwise you'll be there all day trying to get it back in line.
Basically, you need at least one jack and axle stands.
Reviving an old thread.
Can you fit these without the need to support the rear beam? I just thought there could be the chance that the weight of the car could make it difficult to refit the rear shock bolts?
