Wider spacers on rear?
  Clio R.S 197
Hello when i bought clio 197 it came whit spacers 20mm rear, and 10mm front what are prons and cons of this shoud i put 20mm on front end to? Only thing it woud be a problem is if i woud put 20mm spacer on front to the wheels woud start rubbing the arch.
mossyv6
  Trophy,V6,5GT,AG200
20mm up front, 25mm rear. My car is sat on Bilstein B14’s quite low, standard 200 speedlines with 215’s tyres with zero rubbing and drives arrow straight :)
  Clio 197
I believe a wider rear track will make a car more prone to understeer. However even though the spacers at the rear may be longer, what is the overall track length front and rear?
I've got ET45 alloys and agree that the rear should come out another 5mm to get the best stance.
