will 310mm discs fit under 16inch turinis?
What calipers are you using?
You should be able to though with most calipers sotck etc after all its only 30mm more than stock and there 33mm of clearance on the alloy with stock brakes.
  320d
Not much point putting larger discs on if the calipers are stock to be honest
I had 300mm discs with hi-spec 4 pots behind turinis and there was about 3mm clearance so 310mm will be tight
