u sure? have u done it? measuring the width briefly tonight the bonnet is a fair bit wider than the boot? got a 2 and half hour drive to pick it up so really need to make sure it does or im fucked.
I'd say so, quite easily.
Put it in lengthways & diagonally instead (the ladies love it like that) :rasp:ie: don't put the bonnet into the boot the same orientation as it's fitted to the car, turn it through 90 degrees so the front of the bonnet is facing the side of the car, then tilt it up on 1 side and you'll be able slide it right in
Headrests out, pull base part up against front seats. Fold rear seats down. IIRC it might lean up against the front seats. Was a good while ago i did it
the bottom half pulls straight out, no bolts or nothing. put your hand in the gap between the top and bottom half of the rear bench and just pull it up
