will it wont it--- start
  clio 172 sport
pulled up the other day no problem, went to switch my engine back on and it wouldnt turn over, everything else was fine and on.
Battery ok, so last resort i bumped it and it started, switched it off and started by the key ok straight away.
same thing happened again a couple of days later....
Daz.
  Clio 200 RS EDC
I had that on my old car, turned out to be the started motor power connector was loose.
  Clio 172 Ph1.
Mine did it too.
It was down to a very common clio problem here in denmark.
The little wire on the starter corrodes. Give it a nice clean, im sure it will work.
