will my car fail its MOT ?
Car  2003 clio 172
Got my MOT booked for friday and on the way home from work tonight driving behind a lorry and got a stone chip in the windscreen. ive got no time to get it sorted ! is this goin to fail the MOT ?
get it repaired before it cracks, they dont take long to do.
Usual cost is around £30-£50 if your insurance wont cover it.
I easily found a guide online through a quick google, from what I can remember it needs to be less that 1cm large in a certain area infront of the driver, and 4cm where else on the screen :)
Any chip in the swept area of the wipers that is directly in front of the driver (about 300mm width right infront of you) larger than 10mm diameter or a lot of small chips that together restrict your view but on their own aren't over 10mm diameter is a fail. Anything larger than 40mm diameter anywhere else in the swept area is a fail.
So if it's just a little chip, it should be fine wherever it is on the windscreen. If it's right infront of you when you're driving, better measure it to make sure it's under 10mm.
