Will these fit a 182
Gary G had a set of Rota's and had issues with clearance on the calipers, also standard cup wheels have an offset of ET45 so you may have issues with rubbing, especially if you've lowered the car.
  182 Cup
I've also had Rota wheels on my car also 16x7. What ones are they? As far as I know most (if not all) Rota wheels are available in ET45 - unless you're buying second hand? I had a caliper clearance issue on the rear wheels only, easily sorted by small spacers.
  BlackGold 182
Slipstreams ....
Wat size spacers did you use?
Ive emailed POTN and they've replyed saying they apparently can get the right fitment for my car, so hopefully they are right.
So i need ET45 and not ET40?
yes, cup packed cars have ET45 offset. It's actually raised in the casting (along with the width and diameter of the wheel) on the wheel if you pop the centre cap out.
