will these fit?!
cheers mate might try him tomorrow then
in the mean time does anyone know if these will fit? i think russ provides them in sets of 4 and i only want 2
dont see why they wouldnt fit, only thing is, it doesnt tell you the bore size, which is 60.1 on the clio, vws are slightly smaller iirc, i had to get my vw fitment adapters bored out to fit the clio
there going to go on the hubs tho arnt they? so correct centre bore size would be needed, if the center bores to small, they wont fit over the hub, if there too big they will but u will need spigot rings, otherwise you'll have a hole load of pressure on your wheel bolts. so yeah as well as the pcd (4x100) thats needs to be taken into consideration so does the center bore size
