will they fit? ad08r 195 55 15
Dex90
  11Megne250/02Clio172
Hi All,
wanted to double check before buying as I can't find 195/50/15 AD08R anywhere anymore. will 195/55/15 AD08R fit my clio 172 with speedline pro 1.2 15x7 ET35(i think) without scrubbing? it looks like ad08r only comes in 195/55/15 now? the car is lowered with cooksport springs.
thanks all.
deanoE30M3
You can get the new AD08Rs from demontweeks!
You can use a tyre size calculator to work out the new diameter and circumference, and therefore if it's like to scrub and how your speedo would be affected.
adamlstr
You can use a calculator, but AD08R are massive. Even if you placed them next to a different 195/55R15 tyre.
On just lowering springs, you should be fine.
