It always needed petrol. I dont think it ever went anywhere without the light flashing.Quote: Originally posted by Djw Dave on 09 July 2005
Thats fast, think it needs some petrol though. lol
Yep no problems at those speeds ever over 120 its fine on the race track.Quote: Originally posted by Rick on 09 July 2005
Cant believe how fast it gets from 70 to 100. Very impressive. It also looks very stable as well, mine starts getting all lairy at that sort of speed.
Im typing with only one hand at the moment.Quote: Originally posted by Martin. on 09 July 2005
It not diesel edde! Maybe you would like this beast...?
http://s11.yousendit.com/d.aspx?id=2MSAV76P03DB9343I4SV86GZHAclick
Not sure what the bits are and not achually finished yet but there loads of wiring and plugs going nowhere eg foglight wiring which can come out. Looking at all that loose wiring round the aux belt got me all woried thinking what would have happened if it had got stuck.Quote: Originally posted by Martin. on 09 July 2005
LOL, what you ripped out fella? Already got my driveshafts on so they are staying on ....gonna take my old williams ahem driveshafts back to pick up 20 quid...
u sure mate?Quote: Originally posted by Wantawilliams on 10 July 2005
Is that a valver or willy? The willy I went in last week pulled to 150 quite a bit quicker than that so Im assuming thats standardish or a valver?
Its a Williams 2.0Quote: Originally posted by Wantawilliams on 10 July 2005
195/55/15 wheels on standard alloys.Quote: Originally posted by Wantawilliams on 10 July 2005
I just read the title :S woops! I assume its standard then or has huuuge wheels?
valver LOL! Doubt you see a valver that quick... youre right though the car should be faster for the spec I believe with a meg btm end this car could be mental.Quote: Originally posted by Wantawilliams on 10 July 2005
Is there any reason why his should be so quick? Chriss I mean?Quote: Originally posted by TheJesus on 10 July 2005
BigChriss valver is a 2.0 though and by all accounts is mint and silly fast. Like Martin says, that Willy would be mental with a new or recon bottom end... and personally Id change the cams for a lower duration, like 260ish... then I think it WILL be the car to beat. imo
Could just be a good engine with good sealing pistons which hasnt been reved to death all the time. Some engines just are better ven with new 172 engines its the same Chris is a quick one faster than any other 172 I think same with Yozzas old engine it was a quick one.Quote: Originally posted by Wantawilliams on 10 July 2005
Yep I think Id have to test a few engines compression ratio and find a good one or buy one at random rebuilt it completly and then swop bottom ends.Quote: Originally posted by TheJesus on 10 July 2005
well only reason I think 260 cams is due to the low reving nature of the engine, besides, the cars all running the silly quick times are on 260s. not sure on the megane bottom end either, there not necessarily faster, i think it just depends if your lucky imo. northys bro Andy has one seriously fast williams by all accounts, wasnt too far of 2 lives and its std... so should easy run low to mid 14s
