If you are going to fit a williams exhaust manifold you will also need the down pipe and cat as they are different to the 16v and will not match up. The 16v manifold design of 4-2-1 was homologated for the Williams rally car as it was found better for torque on acceleration. Although ugly the 16v set up works well on a 2.0l. The williams manifold system is a 4-1 which hellps with top end power. The megane 2.0l 16v has a fabricated manifold like found on the williams but is set up 4-2-1 with the twin section as seperate pipes at the manifold to downpipe split so again will not fit the 16v unless complete with down pipe and cat again. Space would also be very tight with the megane manifold as the split is much larger in area the either the 16v cast or williams fabricated systems. Hope this helps to crear things up.
Cheers fella! But i have waited this long im gonna wait till i get my beast done!! Ive never been in a willy or seen one go so it will be a shock!! Im gonna get a stage 1 chip too from HP!!
When i get mine done we will meet up and compare thou mate!
Im just outside Huntingdon mate! Where bouts are you?
