Window Switch Wiring
  PH1 172 Sport
Ive had my PH1 172 since before christmas now. The previous owner had both the window regulators changed. However one is obviously wired back to front as when I press up on the passenger side window it goes down. Can I change the wiring on the switch to compensate for this or do I have to rewire the regulator?
i would go for the wire on the regulator thats prob where its been done wrong.. im sure when you changed the window regs on the clio you had to get another piece of wiring loom as the plugs were different ??
i might be wrong tho !!!!!
