Wipers - frost
  BG Clio 182 FF
How do I get the wipers to stay up in a central position so I can tuck some cardboard under them to stop the screen frosting over?
Ol’ Tarby
  Clio 220 Trophy
Really?? Seat altea's/toledo's you can't do it. The wipes hide up the side of the screen so even when you turn the ignition off, they still go back to the park position.
Yup same with newer faux halls too
DrR
  VW Golf GTD
I'm doubting myself, might have to go out and check now!
Ol’ Tarby
  Clio 220 Trophy
In the front? Are they as visible as the ones in the rear?
Yeah in the front lol that's where the windscreen is usually found :p
they are visible but nothing like the ones on the rear screen. They're really small gauge wire that you focus past so you don't really notice them
Jaff.
If your really looking for them you can see them. They're really tiny squiggly lines about 3-4mm apart going down the screen not noticeable at all really. Couple that with a button that knocks air con and max blowers on and its literally 30 seconds (in this weather, longer if there's proper ice on there) and you sweep with the wiper once and its clear as day :)
DrR
  VW Golf GTD
Someone on a car enthusiast website has never seen/heard of Ford quick clear front windscreens?
Jaff.
I've never read up on little details of fords lol
...bar the new 'anti tw*t your door of someone else's car' protectors on the new fords
only on the focus atm.
you know f**kall :p
james - they're on other cars too but not mass market. Mainly because Europe don't have such damp weather as us so European car manufacturers don't see the point
DrR
  VW Golf GTD
I just remember being a kid going "daddy daddy what are those lines in the windscreen" and he explaining it.
  Clio 182
Bed sheet and secure it in the door jams. Works for my dad.
My friend did this, except he didn't get a frost it rained instead, and all the water traveled through the sheet into the car and filled his footwell with water, which is were is ECU was, killing the car.
My recommendation... Don't shut a sheet in your door.
  172 cup
Hahaha these conversations have been cracking me up, and yeah I'm quite surprised people haven't heard of the quick clear windscreen, I do like a ford but I wish they didn't hold copyright on it!
  172/v6
My Ford Escort had a heated front screen back in 1989 and it was standard equipment ! Don't know about the newer Fords but mine used to take an eternity to clear the front screen of solid ice , it was fine for a light frost and excellent at de-misting the interior side of the glass though. I had fitted an auto-start alarm too so I just hit the button 5 mins before I set off to work and the car was clear and toasty-warm !
It's rather sad that a quarter of a century later , we are stood outside with ice-scrapers and numb fingers !
De-icer is a horrible chemical and shouldn't be used (bad for wipers , glass and paintwork)
Ice scrapers do scratch your windscreen , a credit card is much kinder
I've poured hot water on my windscreen for years and never cracked one (it is safety glass!) Boil the kettle and add a cup of cold water , however , below -3oc , the water will just re-freeze almost immediately ... also remember that rubbers (window seals) do not like these temperature changes and it will cause them to go grey and deteriorate much more quickly than usual
If you have a phase 2 172 or a 182 , then you will have to consult your handbook at the auto-lights/auto-wipers section ... if you have auto-wipers "ON" , they will return to their original position regardless of whether you pull the ignition key at the top of the stroke , however , if they are "OFF" , the wipers will stop wherever they are when the ignition is turned off !
  1.6 Focus, 1.6 122S
Hot water freezes quicker than cold water. Cold or teped water is still warmer than ice so your better off using that than boiling a kettle.
  BG Clio 182 FF
Lol cardboard will just end up peeling onto the screen surely?
Cardboard !?
Has warm water not been invented in your part of the country ?
Thread got busy :)
Buy one of these:
Drink what's inside :cheers:
Break open the box, put on the screen shiny side up.
Lasts ages and doesn't go soggy - also makes it looks like the car is owned by a gyppo so good when parking in dodgy areas.
100%. Google it.
I have googled.
Sounds like it only happens under certain conditions, not all the time.
And hot water will still have more energy than cold water so will still melt more ice, even if it does ultimately end up re-freezing faster than cold water would have.
But in reality cold water normally has more than enough energy to melt the ice of a car windscreen for long enough to use the wipers to clear it.
  1.6 Focus, 1.6 122S
Hadn't realised the certain conditions part of the phenomenon. I do know it has an effect on windscreens though as when using hot water on mine in the past it has re frozen so quickly that I couldn't get the wipers on in time ! Haven't had that problem to such a pronounced degree as when using cold water.
