Wireless Webcam
Looking for a wireless USB cam, has to be small ( not bullet point ).
It either has to be powerd by the usb 5V or by a 12V DC power.
Has any one got any good links.:-) thanks :-)
Can some one please explain "Network Webcam/IP Cam Security", And how would i be able to use that as a webcam ??
it connects to your network using cat5 or wifi. Software needed to turn it into a webcam. Can usually view pictures on them in a web browser.
whatever camera you get is never going to have a transformer inside it so itll run off low voltage dc and have a power adaptor so if your using it in your car you can easily step down 12v to whatever the power adaptor says with a resistor. So you dont really need to bother about the power side of things.
You can also get in car multi voltage adaptors if you arent comfortable with electronics. that plug into the ciggy lighter (can hard wire it in if you want) and can select common voltages like 3 4.5 6 9 ect
for all the hassle you'd be far better getting a cheap wired (usb) one and putting up with the wires if its going in your car, youd save like 40 or £50
can get cheap as chips usb webcams rather than the expensive network cameras.
p.s im assuming this is for your car pc?
Yep it's for car pc, and i might get a good wired one that will clip on my mirror
IP cam seems to much trouble.
Yup. Thats why you see signs, "You are in a CCTV area" etc.
You can just film hot females for your own wanking purposes and not tell them! ;)
