wiring amp to battery
  wrx sti ppp (305bhp)
where do i put the wire going from the battery to get back into the car, cant seem to find any holes, help please, its pis**** me off!! cheers
You sure you should be let loose with electricity and tools? ;)
Bonnet release cable goes through the bulkhead from the bonnet release lever in the passenger footwell to the catch in the slam panel the keeps the bonnet shut. If you look in the passenger footwell under the glovebox you'll see where the cable goes through. To feed the cable from the engine bay you need to unclip the power steering resevoir from the bulkhead and put your hand between it and the heat/sound deadening material and you'll be able to feel where the grommet is. It's childs play took about 10 mins in the dark to run the cable from the battery to the boot when i did mine.
