Wiring help for central locking.
Car  Fiat Panda 100hp
I have just installed my alarm and it works a treat.
There is a orange wire with my alarm and the instructions say its to connect to my central locking so that wen I arm the alarm it also unlocks my car. Where is this wire for the central locking that I need to hook it up to???
Thanks in advance.
if its a Mk1
Make: Renault Model: Clio Year: 92>95
Siren Location: N/S Bulkhead
Cable Entry Point: N/S Bulkhead
Bonnet Switch Location: N/S Front Panel
L.E.D. Position: In Dimmer Switch Or Spare Blank
Central Locking Type: Positive Multipoint
Vehicle Wiring - Colour/Location/Function
Fuel Cut: White Wire Multiplug N/S/F Of Dash (Top)
N.B. Dash Top Panel To Be Removed
Starter Cut +50: Orange Wire ) Multiplug N/S Top Of Dash
Positive (Min 2mm2) +30: Red Wire ) (Top Of Dash Removed)
Ignition +15: Yellow Wire )
Hazards: Brown And Orange Wires At Rear Of Hazard Light Switch
Door Switches: Pink/Grey O/S/F Door Switch
Central Lock/Total Close: Orange Or White - Lock
Brown Or Pink - Unlock
At CDL Switch In Centre Console
Boot/Hatch Light: Violet/Grey In Heaviest Loom To Rear On O/S Sill Or
Violet At Boot Lamp
Ground Point: Use O.E. Ground Point.
Ultrasonic Position: At Least 300mm From The Nearest Air Vent
How does I connect my 1 cable to these?
