Wiring loom harness and Spark plugs/remap
Apparently it needs all of this work carrying out, loom harness covered on warranty whereas spark plugs and remap are not. The latter they said would cost £100...for frickin spark plugs?!
Wiring loom is warently (assuming your car is under warently otherwise you'll have to see if you can get a % payment from Reault goodwill).
Spark plugs since your cars not a 172 are only check £15 or so from halfords etc the 172/182 ones are expensive ones.
Why do you need a remap if the ECU maps are broken the like the loom its under warently and you'd realy notice a propeblme you only need a remap to get the fueling right if you've got aftermarket cams etc done if they need to reload the normal maps its under warently or a good will payment from Renault would be expeced or if you have to pay then it shouldn't be much.
plugs from the dealer are cheap
tell them to bugger off about the reflash, that is a warranty claim
whats the age/milage of the car??
