wiring loom --pls help! quick
i will try to explain so please read...
I had a kenwood head unit in my old car, a corsa. and i had a amp fitted professionally with frount and rear speakers...it worked well gud! so when i got my clio the time came to rip it all out and its been in my bedroom since as am having trouble and a lack of confidece to fit my self so heres the problem........I took the wiring loom which was used in the corsa and connected it to the clio bits behind the now removed standard stereo and conneced it to the kenwood now when i switch it on only the rear speakers work..no frount doors and no tweeters WHY IS THIS? I have not fitted the amp but if i was to wire the amp up to existing wiring loom WILL IT WORK AS B4?
Also if the wiring loom am currently using has the wrong configuration of wires will it cause a fire or simply not work correctly...car electrics are scary PLEASE HELP QUICK!
hope u understand
You need to connect it to hte speakers, you will need to find the correct wires for the front speakers and connect hte cables to that.
Probabily what is easiest is to run new speaker cables, dfrom the speakers t the amp, rather than suing your standrad loom, then jsut connect the RCA and remote leads to your HU
