the 172 is the DON... just need to fit my jl subs n all the necessary gibblets that come part n parcel... ne suggestions where to run power cable earth rcas n all the rest on the 172 mk2???
rcas along the drivers side behind the plastic sill trim and 1/4 panel and the earth through the grommet in the bulkhead the bonnet cable goes through (to get to it you have to pull the pas resevoir up and then reach between the heat/sound insulation on the bulkhead) then along the passengers side sill behind the trim. as for the earth i used the bolt that holds the rear seatbelf stalks in place
