Wiring up my Sound System
Car  Clio 1.2 16v
Hey all,
I have just received a few parts off my brother to help me setup my sound system in my new car,
Now these parts dont have any instuctions so I am a bit clueless as to what I need to get them working,
I am also looking at buying a new headunit to go with them so any recommendations to one of these would be appreciated also.
I have took some pictures of the subwoofer and amp that he gave me today as he is as clueless as me:
Now I realise there has to be some kind of power from my headunit to the amp and then cables going from the amp to the sub woofer. I am also planning on putting some 6x9 speakers in my parcel shelf and wondered if that would be possible.
I know I am asking alot of questions but I am a bit of a novice at car sound systems!
Thanks alot,
Sam
youll need a wiring kit-360w is all youll need i have these in stock and can send out to your door if you wish?would contain all wiring required to fit it.
you could fit 6x9s but wudnt be able to run them off that amp and if you fit 6x9s they will just be drowned out by the sub.get a decent set of front comps and set up your sub right and youll be more than happy.also can help you with headunits if you wish?drop me a pm
matt
From the Pic above, you need to get a phono cable from the back of your head unit to where it says 'in' on the amp
GND in the pic needs to be connected to a secure metal point in your car such as a bolt under your seat. The REM needs to be connected ro the remote from the back of your head unit. B+ needs to be connected to the positive terminal on your car battery. The part on the right of the amp in this pic is where you connect the speaker to the amp.
You need to connect speaker wire from the negative on the amp to the black and from the positive on the amp to the red.
