Wish bones & ball joints?
Car  172 cup
Ok i have a few different rattleing noises comming from the front end also feels abit loose. I want to replace the Wish bones, CV joints and track rod ends and maybe tie rods.
Just wanted to check where the best place to get these bits is?
Is there a difference between the 172 cup and the 1*2's for these bits or are they all the same?
Thanks Mark
I believe the wishbones are different on the 172 cups, they are designed to give a bit more caster.
Ok sweet thanks for your reply do you know the best place to get these should i just ring renault or would that be expensive?
I'd get them from Renault mate, there's a guy on here isn't there? Check the traders section. My experience of pattern wishbones and bushes is that they are usually worse than the old ones you take off!
